Aspire 4 problem
Posted: Sun Jan 26, 2014 4:54 am
Anyone have an idea why the zero plane changes from 0.00 to -0.50 for no apparent reason ( aspire 4)?
When creating a dish shape the first one works and the zero plane remains at 0.00 but the second one changes the zero plane to -0.50. I've repeated the same job 5-times from scratch and the same thing happens every time even though the second recessed dish is not necessarily the same as the previous job.
I have not determined exactly when the change occurs but it affects the entire job.
I've tried grouping the zero plane with the dish before creating a new dish, same result.
I've tried using the zero plane at the beginning and the end, same result.
The result is that all the entire job, including v-carving, is 0.50" too deep.
I also notice that when I hover over the 3-d view, pushing the shift key changes the zero plane from -0.50 to 0.00 as long as the key is held down.
Thanks in advance,
Dale
Thanks in advance,
Dale
