Star Trek Chess Board
- dealguy11
We were commissioned to do this piece by a die-hard trekkie. This was my first attempt at cutting and etching acrylic and I'm pretty happy with how it came out. The etching was done with a diamond drag bit, game boards were cut out and holes made with straight o-flute bits, and edges were polished the hard way, by hand with sandpaper (I don't have a buffer).
Steve Godding
- Model of CNC Machine: homebuild / VCP 8.0
Re: Star Trek Chess Board
Dealguy,
Nice job, no idea how to play and don't want to know
To deal with edges
Clean up saw cuts on acrylic with light passes on router table or jointer (just a few thou. at a time) (or you could use cnc like you did), wipe edge clean and fan edge with a hand held map torch.
It takes a little practice, but edges become clear and polished. No sanding needed.
I route the edges with paper on, then remove paper on side I'm engraving and engrave, then remove bottom paper, rinse under running water to clean, then torch edge to polish
To deal with edges
- dealguy11
I'd heard about the torch method, but only had a little bit of acrylic for this project and didn't want to risk ruining the work. There are a few scraps left over so I'll try it on those. Thanks!
Steve Godding
Hi Steve,
Love the board.
Murphs,
Love the board.
Murphs,
- bill_w
- Model of CNC Machine: PRSalpha BT48
Very nice, well done.
Computers-Yuk....I should junk it...It never does what it should do...only what I tell it.
- zeeway
Trekkies rule.
Angie
Angie
I'm about to try my first acrylic cuts, what size bit and what bit and travel speed did you use to cut out the shapes?
- ssflyer
- Model of CNC Machine: ShopBot PRSAlpha 96x60
That's pretty cool - always wanted to give it a try, but the rules seem to change... Here's a link to supposedly the latest iteration.
Ron Sloan
- dealguy11
I used both 1/4" and 1/8" straight O-flute bits. The screw holes were done with the 1/8" bit and the cutouts with the 1/4" bit. The rpms were fairly low - around 6000 or so. The feed rates were about 100 ipm, but, as always, the speed is going to depend on your machine's abilities.
Steve Godding
