This design is the best so far as with different o rings you get different hold down techiniques
with 4 of these hold downs ,you7 get a lot of vac power to hold a large surface area
Took about 40-45 mins to make
also added a few tests using 2 vac clamps
flexible vac hold down device and tested
Re: flexible vac hold down device and tested
That is a very nice clamp design.
What size o rings are you using and where did you source them from?
bob
bob
the orings came from lee valley tools less than 6.00 per package of 3
Great job..
I assume the materials from AllStar gaskets would work as well. Those O Ring gaskets very well though.
It the Aspire file on your clamps something that you would be willing to share?
Again, Great job,
Kelly
Again, Great job,
Kelly
Dyna CNC Plasma/Router
USAF-- Fadal 4020, Shopbot PRT 4X8
Stan
I really like your Vac hold down.
I have made several of my own but nothing like yours.
Would you be willing to share the file?
Bill I
Bill I
- rscrawford
- Model of CNC Machine: CAMaster Cobra 408 ATC, ShopSabre IS408
That is a classic vacuum pod design!
A couple of suggestions if you want a vacuum hold down for very accurate work.
There needs to be a positive stop, so the Z-height is always accurate. The easiest way to do this is to have a gasket that will compress enough that your workpiece sits directly on the vacuum grid. If the workpiece is sitting directly on the gasket with no positive stop, then the z-height will vary depending on the strength of the vacuum (the gasket can deform unevenly).
To go along with this, you want the vacuum hole to be in a groove, rather than on the top.
Russell Crawford
- stephenr
- Model of CNC Machine: Shopbot PRS Standard 48x96
Good information. Thank you.
Stephen R.
Stephen R.
