Stairway panels in 3d using Vector Art's Wildlife series
Postby AJF » Thu May 12, 2011 3:00 am
I was approached by a couple, after they saw some 3d carvings I had done for a local craft fair. They asked me if I would be interested in making a series of 36 panels for the stairway and balcony railings in their house (see picture of original stairway railing). They wanted the panel's to incorporate a northern theme of animals and scenery. The panels range in size from 10" wide by 24" high, up to 6ft wide by 24" high. We decided on using red cedar as the wood, with the panels being 1 1/4" thick and the carvings being cut to a depth of 3/4". I had already purchased Vector Art's Design and Carve Wildlife series, so using that as the starting point for the design, we spent several months working through a series of design scenarios until we finally came up with a series of scenes that they liked. The stairway panels would feature animals in the larger panels and trees in the small panels and for the balcony railing it would be a large mountain scene spread across approximately 20ft. Building the panels, and doing the cutting and finishing would take another couple of months. The panels are mounted in u-shaped wooden cleats to allow for movement. Some of the panels took 24 hrs or more to cut on my ShopBot PRSstandard and all the designing was done using Aspire.
Having taken up CNC routing after my retirement from teaching, I've found it a very creative and rewarding experience and you even can make a bit of money at it. I've attached some pictures of the panels below, hope you like them.
AJF
Location: Hamlet of Mt. Lorne outside of Whitehorse, Yukon, Canada
Model of CNC Machine: ShopBot PRSstandard 48x96
Re: Stairway panels in 3d using Vector Art's Wildlife series
Postby esteeme1 » Thu May 12, 2011 3:41 am
In the Navy they would give you a score of "B" "Z" or Bravo Zulu! It is the ultimate of complements. A higher mark cannot be obtained. Congratulations on a job well done! That is just beautiful. Some things you just want to keep for yourself I'm sure you know what I mean.
With your 24 hour cut did you make any stops to cool down your spindle/router?
Jim Darlas
"Can Do!"
http://www.esteemedwoodcrafts.com/
http://www.esteemedplaques.com/
esteeme1
Model of CNC Machine: Cobra 404 ATC; ROMAX WD-1; Shark
Postby mtylerfl » Thu May 12, 2011 5:57 am
That is a real "showpiece" - both for you and your customer! Excellent work!
Postby rozprim » Thu May 12, 2011 6:27 am
Very successful work :wink:
Jack
rozprim
Postby tmerrill » Thu May 12, 2011 10:55 am
Very impressive!
How did you end up designing and machining the recess shapes?
Tim
tmerrill
Postby bill_w » Thu May 12, 2011 1:04 pm
Very nice, Excellent work and well done.
Computers-Yuk....I should junk it...It never does what it should do...only what I tell it.
bill_w
Model of CNC Machine: PRSalpha BT48
Postby jasond » Thu May 12, 2011 1:53 pm
WOW!!
Great job!!
jasond
Model of CNC Machine: Homemade cnc
Postby jimwill2 » Thu May 12, 2011 2:02 pm
Incredible!
Jim Williams
jimwill2
Model of CNC Machine: CaMaster Stinger w/recoil, FTC
Postby GripUs » Thu May 12, 2011 2:22 pm
In the Air Force you would be punished. That is because in the Air force no good work goes unpunished and that is, indeed, great work. I am truly impressed.
Joe
Ham and eggs - Inconvenient for the chicken. A total commitment for the pig.
http://www.gripus.com/
GripUs
Postby AJF » Thu May 12, 2011 4:15 pm
Thanks very much for the compliments. The long cut times were broken up into a roughing and finishing cut. I found cutting across grain on the rough cut and only taking a 1/4" deep cut each pass prevented a lot of the problems with chip out in the red cedar. On the final cut I used a 1/8" ball mill, at 10% step over and a speed of 100 ipm. Then there was hours of final sanding and detail work to get it ready for the finish.
The dishing of the panels was learned from watching the tutorials that came with Vector Art's Wildlife series. Plus having to use the sculpting tools of Aspire to finish off the corners. The hardest part of the whole project was doing the mountain scenes on the balcony railing which was a continuous scene across the entire length of the balcony. I've attached some more pictures from the project.
AJF
Postby Redhorse » Fri May 13, 2011 12:16 am
Awesome and Impressive !!!!
Dave
Redhorse
Postby mboydraska » Fri May 13, 2011 2:40 am
Spectacular! Your customers are very fortunate have found you.
HAPPY CUTTING
Mike
mboydraska
Model of CNC Machine: 3 axis homebuilt
Postby JamesB » Fri May 13, 2011 3:24 pm
Al - fantastic project - great finish on everything too. I will drop you an email today regarding this.
Cheers,
James
JamesB
Vectric Alumni
Postby gravirozo » Sat May 14, 2011 3:05 am
ajf
thank you for update.. also for the great photos... its turned out very great..
viktor
gravirozo
Postby sawmiller » Sat May 14, 2011 2:11 pm
i have a staircase just screaming for this in my addition... , think i will do the same, only go live edge on it.
thanks for the inspiration
( got to finish the addition first thou :D
dan
In the heart of Tn
sawmiller
Model of CNC Machine: joe's rack and pinion hybrid
Next
Return to Aspire - Gallery
Users browsing this forum: Google [Bot], spyderxxx and 19 guests
