How to import .RLF-files to Aspire?
Postby ilsaarin » Thu Jan 29, 2009 8:09 pm
Any tips? I just noticed that those Artcam relief files can not be imported. And I have quite a lot of them. I am just playing with trial and I am going to purchase Aspire before introductory offer expires.
Ilkka
ilsaarin
Re: How to import .RLF-files to Aspire?
Postby Tony Mac » Thu Jan 29, 2009 9:48 pm
Hello Ilkka,
ACP can save .rlf files as an STL mesh that Aspire wil limport.
Tony
Tony Mac
Vectric Alumni
Postby ilsaarin » Fri Jan 30, 2009 1:59 pm
How can I do that? If I open the relief in Artcam pro, I can not save it to any other format than to raster images. Export is not possible either. I think I should ask this from Artcam forum but I bet here is someone who knows how to do that.
ilsaarin
Postby joecnc2006 » Fri Jan 30, 2009 2:29 pm
Did you send an e-mail to your Artcam pro dealer? Where you bought it they should give you free technical support. You would figure of 7,000 they would answer a few questions from you free of charge.
joecnc2006
Postby tgm » Fri Jan 30, 2009 6:39 pm
Ilkka,
In ArtCam you have to create the STL before you can save it. If you got to Relief>Create Triangle Mesh you open up the Mesh Craetor dialog which allows you to create the STL and then save it from there. Fairly starightforward.
Good Luck,
Tom in PA
tgm
Postby ilsaarin » Sat Jan 31, 2009 3:23 pm
Thanks for your help. I managed to get the file imported. Quality seems to suffer quite a lot.
Ilkka
ilsaarin
Postby JamesB » Sat Jan 31, 2009 7:29 pm
The quality of any STL from any software is a function of the triangulation tolerance. If you set it to 0.0001" when you create the model you are exporting then you will get something which to the eye/machine will essentially be smooth.
JamesB
Vectric Alumni
Model of CNC Machine: None
