How could I change the appearance?
Paul R
Post by Paul R »
Hello,
How could I change the appearance? I´m testing the trial. If I would change the appearance of the compenents in the component list, their is only one choice (same as parent) available.
Paul
mark296
Re: How could I change the appearance?
Post by mark296 »
Paul R wrote:Hello,
Paul
I believe you do that before you put it in the compenent manager with the filp, rotate and mirror comands on the first page.
Paul R
Post by Paul R »
Hello,
what I mean is shown at the photo. I have no choice to select a different color for each component.
Paul
BrianM
Vectric Staff
Post by BrianM »
Hi Paul,
This looks to be a UI problem on your operating system. There are 4 entries in the list, I would guess that if you use the up/down scroll buttons to the right of the 'Same as Parent' text you could get at the other entries.
What operating system are you using?
Brian
Paul R
Post by Paul R »
Hi Brian,
I´m using Windows 2000 SP4. VCarve works fine with it.
Paul
