Convert .dae file to .stl file, any suggestion on how.
- lovebugjunkie
- Model of CNC Machine: Romaxx HS1
The sketchup community has some very nice free 3d object. A really neat trick would be how to take the .dae file that sketchup creates and convert it to a .stl file without spending a few hundred $$. I have tried a few suggestions I found on the net without success.
Re: Convert .dae file to .stl file, any suggestion on how.
There's a thread on this in the Cut3D forum that might be helpful,
http://vectric.com/forum/viewtopic.php?p=21426#p21426
Tony
Tony
- lovebugjunkie
Thanks Tony.
edited: got it, went back and read the thread and found that the "explode" option that was mentioned did the trick.
thanks again.
thanks again.
Excellent work!
Any chance of posting 'the process' so the rest of us can do this?
Tony
Tony
- bgriggs
- Model of CNC Machine: Warp Drive Project R&P
How about the free Sketchup to STL plugin......
http://www.cadspan.com/tools
Make Magazine had an article about it.
http://blog.makezine.com/archive/2008/1 ... 6B48984890
Bill
Bill
- Turtle49
Thanks Bill,bgriggs wrote:How about the free Sketchup to STL plugin......
Bill
That worked really well. I just installed it and output the stl file and it came right in to Aspire. Great tip!
Tim
Tim Hornshaw
www.HornshawWoodWorks.com
- lovebugjunkie
Thanks for the tip on cadspan Bill, works better than any other program I tried.
Also a lot of free 3d and low cost (and some not so low cost) items can be found at http://www.turbosquid.com/Search/Index.cfm
M16 is an example I dl’ed from them and the results in Aspire with no clean-up.
The eDrawings Publisher free version from Solidworks integrates into Sketchup and gives you an STL export function.
As I've been a Sketchup Pro user for years I wasn't sure what the issue was until I realised that the free version doesn't have the full range of export functions that the Pro version does.
