where to put textures
Postby Xxray » Mon Jun 03, 2019 5:49 am
have some texture bmp I would like to add to aspire, have done it before but I been tearing through folders and am unable to figure ouit where to put them - am using 8.5 windows 10
Doug
Xxray
Re: where to put textures
Postby Adrian » Mon Jun 03, 2019 8:22 am
I put mine in Public Document\Vectric Files\Material Images
Postby martin54 » Mon Jun 03, 2019 11:52 am
What do you want to do with them? If it is just for visual purposes then you can save them in the material images folders as Adrian has said.
If they are ones you want to be able to machine then you would need to save them as 3Dclip files first I believe. That is what I have done in the past at least :lol: :lol:
I exported them as 3dclip files & then added them to the non tileable textures folder within the clipart.
Postby Xxray » Tue Jun 04, 2019 5:59 am
martin54 wrote:What do you want to do with them? If it is just for visual purposes then you can save them in the material images folders as Adrian has said.
Ok I'm a tard, how do you export as 3dclip, I don't see the option. I'm showing eps, dfx,ai and and svg.
Doug
Xxray
Postby Adrian » Tue Jun 04, 2019 7:29 am
3Dclip is an export format for models and you access it by right clicking on a model in the Component tree.
Postby Rcnewcomb » Tue Jun 04, 2019 5:53 pm
The 3Dclip format is one of those hidden gems in Aspire. Saving your 3D textures is a good idea. I also convert my STL files to 3Dclip format. This makes them much easier to work with since the 3Dclip format works and plays well with the clipart tab for organizing 3D clip art.
Postby martin54 » Tue Jun 04, 2019 8:59 pm
Rcnewcomb wrote:The 3Dclip format is one of those hidden gems in Aspire. Saving your 3D textures is a good idea. I also convert my STL files to 3Dclip format. This makes them much easier to work with since the 3Dclip format works and plays well with the clipart tab for organizing 3D clip art.
Never thought about converting STL files, thanks Randall :lol: :lol: Converting them to 3D clip files means they will show up as thumbnails in the clipart folder, something that would be quite handy :lol: :lol: :lol:
