Toolpathing Hair vectors that continue off the Head
Postby JoniEl » Sat Apr 06, 2019 7:14 pm
This image shows my Lincoln model that I'm trying to toolpath with 1/8" ballnose for beard and clothes, and 15-degree V-bit for Hair and Beard. There's a lot I don't know.
1. Since the hair runs off the head, the Heights change and I get this 2nd image from the toolpaths:
2. If I do the head first and make boundary for the Hair, it cuts away where the hair should add on.
3.If I Boundary just the head with the Finish tool. then try to add beard or hair v-bits, I only get the 2D vector used to permit the 3D Toolpath.
I'm wanting to make the first image with the V-bit limit heights correct. Thanks for any straightening me out.
JoniEl
Model of CNC Machine: Stepcraft 840 Black Edition
Re: Toolpathing Hair vectors that continue off the Head
Postby SteveNelson46 » Sat Apr 06, 2019 8:15 pm
If you already have the model of the face and are trying to add the hair, try putting a check mark in the "Project toolpath onto 3d model" checkbox.
SteveNelson46
Model of CNC Machine: Camaster Stinger with Recoil Lathe
Postby TReischl » Sun Apr 07, 2019 12:48 am
You need to have a base for the hair to sit on.
When I look closely at the model there is a very apparent top of skull line, that line has to go away. you need to add a component that blends with the skull near the start of the hairline on the forehead and gracefully tapers to where the hair meets the base plane.
