Best sealant to prevent glue-staining in Zank V-Inlay
Postby laflippin » Wed Jan 23, 2019 12:07 am
I've started doing a lot of Zank V-Inlay projects using redwood for the female engraving and various yellow woods for the male inlay. I generally use Titebond III for glue-ups because it is very strong and moisture-proof, but it sure does discolor redwood--makes a dark purplish-gray penumbra on redwood which must be sanded quite a bit to fully remove. (Of course, on really intricate inlaid regions too much sanding can essentially "erase" the inlaid wood).
FixitMike kindly suggested pre-sealing the female workpiece before glue-up in order to attenuate the glue-stain problem, and others have at various times suggested that Titebond II might be closer to stainless, at least compared to TB III. Still others seem to swear by cyano acrylate glue.
I'd like to know what specific sealants folks here think are best suited for prevention, or at least reduction, of glue-stains on redwood?
laflippin
Model of CNC Machine: Piranha FX, Axiom AR 8 Pro+
Re: Best sealant to prevent glue-staining in Zank V-Inlay
Postby Rcnewcomb » Wed Jan 23, 2019 12:09 am
Do NOT use TiteBond II on redwood. Titebond original is fine with redwood.
Postby Tailmaker » Wed Jan 23, 2019 2:32 am
Try the "Clear Gorilla Glue" (not the original brown or white PVA one or the CA). It is water clear and does not foam, stain or smudge with ample open time. Easy to sand as well. I use it for all detail assembly work and joinery lately.
Tailmaker
Postby dwilli9013 » Wed Jan 23, 2019 3:50 pm
Tailmaker wrote:Try the "Clear Gorilla Glue" (not the original brown or white PVA one or the CA). It is water clear and does not foam, stain or smudge with ample open time. Easy to sand as well. I use it for all detail assembly work and joinery lately.
+1 but make sure it is the clear gorilla glue. There is a difference.
D-Dub
Dwayne
Dwilli
dwilli9013
Postby laflippin » Wed Feb 06, 2019 7:05 am
Thought I'd update this thread with some recent experience. Picked up a gallon of Rain Guard sealant for about $10 and sponged it on to a piece of redwood that I had engraved with some scrollwork patterns and a wild turkey image. Did the glue-up with male workpieces carved from clear pine using Titebond III which usually stains the hell out of redwood. Long story short, the sealant really helped. Very little glue-staining was apparent, so sanding the project to an acceptable finish was very easy after cutting off the waste backing. Coated the sanded board with satin-finish polyurethane.
I happily recommend FixItMike's suggestion to use a sealant for reducing glue stains in delicate Zank V-Inlay projects.
laflippin
Postby mtylerfl » Wed Feb 06, 2019 4:48 pm
Thanks for the follow-up and photo, Lee. Your inlay looks great!
Users browsing this forum: Google [Bot] and 5 guests
