End Grain inlay question - challenge
Postby jssussex@gmail.com » Mon Apr 30, 2018 1:24 pm
I'm trying to help a friend out on an end grain cutting board that he wants to inlay this image.
The problem is that the facial detail is so fine I don't believe I can successfully carve this. The facial outline is only .046 wide.
I was gong to do an MDF test but then since the cutting board is 1 1/2 inches and he would like to do a 1/2 thick walnut end grain inlay I decide I'd ask the experts here their opinion before I damage a beautiful end grain blank. Also what glues do you use for endgrain. all my experience is in shallow flat grain decorative inlays.
Jim Sussex WI
Heritage Carving and Woodworking
Legacy Maverick 3X5
http://www.heritagecarving.com
jssussex@gmail.com
Model of CNC Machine: Legacy Maverick 3X5
Re: End Grain inlay question - challenge
Postby potzmannwoodshop » Mon Apr 30, 2018 3:41 pm
Reduce the detail but keep the theme/idea, I agree that you will have problems with this inlay is set up currently
potzmannwoodshop
Model of CNC Machine: 2 SCM Routech Record 120s(1999, 2001)
Postby scubanimal » Mon Apr 30, 2018 5:00 pm
Given its a cutting board, and the details of the face being thin, but just the face outline, I might consider using an endmill and going a bit deeper and using an dyed epoxy or something for the fine facial features, then the walnut for the rest.
just a thought,
Ian
scubanimal
Model of CNC Machine: Stinger1 24, Shark HD2 Pro, Aspire,
Postby Trock » Thu May 03, 2018 3:45 am
I've read several tips and all say that no epoxy is truly safe on a cutting board.
Works for an area you know the knifes will not cut into it though.
Agree with Potzmannwoodshop, a reduction in the detail, replace some of the thin lines with stylized wider paths, be creative. Cold be cool.
Best Luck
Trock
Postby highpockets » Thu May 03, 2018 5:04 am
Postby Samson » Thu May 03, 2018 8:38 pm
Trock wrote:I've read several tips and all say that no epoxy is truly safe on a cutting board.
Best Luck
There are several direct food contact, FDA approved epoxies on the market. There is at least one that is completely organic. Absolutely no VOC's, no chemicals, etc.
Samson
Model of CNC Machine: 4x4
Postby mtylerfl » Fri May 04, 2018 12:29 am
I wouldn't be cutting on the "pretty side" anyway!
I would cut food on the plain backside only so I don't destroy the design.
Postby jssussex@gmail.com » Wed May 16, 2018 5:04 pm
highpockets wrote:https://theepoxyexperts.com/shop/adhesives/max-clr-24-oz-epoxy-resin-food-safe-fda-compliant-clear-high-impact-coating/
Thanks this helps
Jim Sussex WI
Legacy Maverick 3X5
jssussex@gmail.com
Postby Mike-S » Wed May 16, 2018 11:14 pm
Wood filler (Minwax) can be used on end grain as well as regular grain.
Mike-S
Postby MTSO » Sun Jul 01, 2018 10:31 pm
I think you might be surprised at the sort of detail you can get with a v-carve inlay. Have a look at mtmwood and his inlayed cutting boards, the main problem with end grain v carving is having the male inlay chipping with the finer detail. I find that by reducing the cutting angle to say 30 degrees on fine detail your inlay has more depth and better glue area (also easier to chip I suppose).
Practice pieces are always the best way of testing your designs.
regards
Brian
MTSO
Model of CNC Machine: salecnc XJ1224
Postby weirdbeard » Wed Jul 04, 2018 10:17 am
Im with Brian
I did this with 30 degree vbit
viewtopic.php?f=29&t=27374&hilit=aussie
(If you have a look you can see the cross at the top of the crown )
weirdbeard
Model of CNC Machine: Jcut
