Best bit for milling corian
Postby mark-s » Mon Apr 16, 2018 10:18 pm
What is the best bit to use when working with corian
mark-s
mark-s
Model of CNC Machine: diy cnc router
Re: Best bit for milling corian
Postby mtylerfl » Mon Apr 16, 2018 10:24 pm
Same bits you use for wood, no problem.
Postby mark-s » Mon Apr 16, 2018 10:41 pm
up cut recommend?
mark-s
mark-s
Postby Xxray » Mon Apr 16, 2018 10:47 pm
Any good sharp mill should do, corian machines beautifully.
Might have to pay attention to RPM until you zero in on the sweet spot, you'll want to be creating chips not dust.
If you get dust that means either the bit is not sharp, your RPM's are not optimal, or both.
I go by pitch so can't really tell you what I use - Feed speed could be a factor as well depending upon what you are doing.
Doug
Xxray
Postby ger21 » Tue Apr 17, 2018 12:18 am
I use the Vortex 4233 for Corian, and it works really well.
ger21
Postby kp91 » Tue Apr 17, 2018 10:31 pm
V bits work great, end mills seem to work better because no grain to worry about. Can be messy, and needs good dust collector
Doug
1 John 1:9
Fredericksburg, VA
kp91
Model of CNC Machine: Digital Wood Carver
Postby mark-s » Tue Apr 17, 2018 11:53 pm
Thanks for the info fellas.
I like the look of that Vortex 4233 bit, so ordered one.
I work with acrylic alot so might give it a test on that.
mark-s
mark-s
Users browsing this forum: No registered users and 9 guests
