Just discovered the quick engrave function. I see some serious possibilities with this, but I need to find out if it is possible to project the cross hatch tool path onto a 3d model. I don't see an option in the dialog for projection onto 3d model like in all of the other tool path options.
Any help would be very appreciated.
Cross hatch onto 3d model in Aspire 4?
Dave
Epilog 24TT 40w and Legend 36EXT 75w Laser Engravers, Roland SP-300V, BabyLoc PR600 Embroidery Machine, Panther 24" Vinyl Cutter, Mighty Presses (hat & T-Shirt), PRT48 Router
Re: Cross hatch onto 3d model in Aspire 4?
No you can't project onto 3D with that toolpath.
I was afraid of that.
Thanks for the help!
Dave
Although you can't map an engrave toolpath to a 3D surface, it wouldn't be hard to replicate what that toolpath does with a couple of line segment arrays, profiling ON the line, and then mapping it to your surface.
4D
4D
