Page 2 of 2
Re: Tapered ball mill
Posted: Wed Feb 21, 2018 1:22 am
by ger21
The big difference is that you can often skip the roughing pass when using a tapered ballnose, which saves a considerable amount of time.
Posted: Wed Feb 21, 2018 4:27 pm
by kaetamer
martin54 - I did, in fact, find a setting error which significantly increased cutting times w/the TBN. Once corrected, cutting times are comparable to SBN.
ger21 - I was aware of possibly omitting the roughing pass but some of my carvings are quite deep - not sure I'd want to push the bit to nearly its DOC - or am I being too conservative?
Thanks to all for info.
Posted: Wed Feb 21, 2018 4:47 pm
by Leo
There is no specific toolpath for a specific tool. Only 3D, pocket, profile - etc
The software (vectric) will calculate the toolpath based on the shape of the cutter (tool) as it is described in the tool database. The radius on the tool tip as well as the tapered angles on the tool are calculated into the toolpath.
Sooooo - the tool data base needs to be set up correctly for the specific tool
Posted: Wed Feb 21, 2018 5:14 pm
by scottp55
I regularly cut without a roughing pass IF!!!! I carefully inspect the toolpath and only see ONE plunge AND ONE lift!!
If the center of the model is a high spot, I'll do an offset toolpath if the first plunge is .125" or less.
If rastering, I'll ZZero...move the bit up so first plunge is only about .125"...Re-Zero Z...cut a few lines...stop and move Z down in stages until I'm at the original ZZero.
In both those cases, you're only cutting the stepover.
Check the file CAREFULLY though!!!
If for instance the model depth is .5", AND my LOC is .5"....many times I'll change the model height to say .47"...Inspect, and cut away.
I'm a smaller stepover guy though as I hate toolmarks as much as sanding
These were all carved with the smallest Chinese TBN with no roughing and medium to pretty dense woods.
Posted: Wed Feb 21, 2018 10:47 pm
by martin54
Posted: Wed Feb 21, 2018 10:55 pm
by Xxray
Any 3d toolpath will require more time than 2d due to the increased z movement and shear volume of lines in the tap file.
Time saving options are, as ger21 pointed out, skip roughing
. What specifically are "deep cuts" and "hard wood" ? Well, you learn that from experience and breaking bits. Tapered bits are tough but of course have their limits, skipping roughing carries risks.
Sometimes I compromise and only do, say, 2 roughing passes instead of the calculated 5. Can also calculate toolpath on a 45 angle which *can* greatly reduce the risk of stress and breakage [this only works with an uninterrupted toolpath from top to bottom, often 3d toolpath will jump all over the place then this won't work].
A risk free method to reduce cutting time is increasing line stepover.
For the finest detail you'd want 8 to 13% for a finish pass but you can often jack it up to, say, 15 to 18% without a perceptible difference the naked eye can see.
Go much further than that though, and you will notice a quality difference that gets worse and worse as the % increases.
Sometimes thats fine if you are only doing a rough ball shape or something but if you are doing the last supper, you want max detail regardless of time.
Finally, having quality bit makes a huge difference as to your final product and longevity of the tool.
I tinker with cheap made in china bits occasionally, by and large though I invest in quality tools for predictable, repeatable and quality results.
http://www.precisebits.com/products/car ... 250b4f.asp
