Acrylic LED sign
Acrylic LED sign
Hi guys, I would like to try something like this on the cnc. I have got myself a 10mm thick A5 bit of acrylic. Is this just done with a v bit? to what depths? I would like to do a outline of a deer with some trees behind it.
- gkas
Re: Acrylic LED sign
I've had excellent success with a diamond drag bit. Spindle is off. I cut on the back side, so I flip the design so it appears correct from the front.
There are lots of approaches to this question. Vbits, drag bits, etc.
- Model of CNC Machine: diy 4 X 4 CNC Router
I did this with a 90 degree v bit.
Milled the base from 3/4 inch oak with 1/4 inch trim.
mark-s
mark-s
Try searching the forum as there is already some excellent advice on producing edgelit acrylic panels, diamond drag bits work very well but you can still get good results using a v bit or an engraving bit. Look out for posts by Xxray as he offers some really good advice
