Spiral Square with an arc
Martin Reid
Model of CNC Machine: Shopbot
Re: Spiral Square with an arc
Post by Martin Reid »
Dear Jay
You can model your twist in SketchUp - Then use Export to DXF or STL (Plugin from https://www.guitar-list.com/download-so ... dxf-or-stl) then drop the 3D DXF into Aspire (or Partworks 3D)
The one I've demonstrated has quite big segments you will be able to make them smaller and give you a better resolution.
Sincerely
Martin Reid
Twisted in SketchUp and Exported
mezalick
Post by mezalick »
Martin,
It's all well and good but your's doesn't have the arc......
I don't know Sketchup so I'm interested to know if you can add the bend to the twist .
Michael
Michael Mezalick
mm@mezalick.com
Martin Reid
Michael
Michael Mezalick has it if you have version 9
SketchUp.. Yes you would be able to 'twist' then bend the 'arc'. The problem is of course having to learn another piece of software. If it was me and I had Version 9, then I would look at Micheal's 'Done with V9 and the wrapped Job Gadget'
Sincerely
Martin
SketchUp Spiral & Bent
mezalick
Post by mezalick »
Interesting,
Thanks Martin.
As I said I don't know much about Sketchup ,,, my bent spiral can be done in any version of Aspire that has the wrapped gadget..
Michael
Michael Mezalick
mm@mezalick.com
garylmast
Post by garylmast »
I guess if I played with it with a two rail sweep, I could do it in Aspire, but sometimes an outside cad software is faster. 30-seconds with Rhino I came up with this. I couldn't post it as a stl or rhino file, so I attached it as a dxf. See if that works. Gary
twisted post.dxf
(187.57 KiB) Downloaded 163 times
Needs to have an arc in it though. That's the issue, it's not a straight post with a 1/4 turn.
garylmast
Post by garylmast »
Just another few seconds in Rhino. However, just guessing on the degree of arc.
Twisted with arc.dxf
(118.44 KiB) Downloaded 162 times
mezalick
Post by mezalick »
Of course there are several other programs that can do this, I would have used MODO, but for me the challenge was to only use Aspire..
Certainly I'm not the only one that can do that....am I ????
Michael
Michael Mezalick
mm@mezalick.com
dealguy11
Model of CNC Machine: Anderson Selexx 510,24x48 GCnC/WinCNC
Post by dealguy11 »
I have made things quite similar to the stair spindle shown earlier. Here is a picture. I'll have to pull up the old file - I ended up using a Multiply sweep to get it to come out right.
Steve Godding
mezalick
Post by mezalick »
Steve,
Correct me if I'm wrong but your designs don't seem to have a bend to them...??
Michael
Michael Mezalick
mm@mezalick.com
dealguy11
Post by dealguy11 »
Sorry, missed that.
It should be possible to add a bend by adding a carefully constructed 2-rail sweep that pulls the design down in the middle, but there is a limit to how much of a bend you can do in Aspire. As always, the closer the surface of the part is to the center line, the more distortion you'll get, and if the center line is exposed, Aspire can't handle it.
Steve Godding
