Hello,
Please have a look at the picture of a guitar I have modeled in Rhino. There is a feature called a belly-cut (or tummy-cut) that is relatively straight forward to do with a 2-rail sweep when I have access to put one of the rails on the side of the guitar body and one on the back. Since the rails are offset in the X, Y, AND Z axis, the resultant surface varies in pitch, or steepness, along its length. Additionally, I am able to control the max depth (1 inch in this case) and the location where that max depth occurs.
Is there a way to create such a feature in Aspire?
How do I creat this 3D feature in Aspire 9.0?
- mtylerfl
Re: How do I creat this 3D feature in Aspire 9.0?
Yes, you can model that in Aspire.
But, if you have Rhino and are already comfortable with it, just save your model as STL or OBJ and import it into Aspire for toolpathing.
Nothing wrong with using a variety of software products to achieve your goals.
- Model of CNC Machine: Romaxx WD-1
Yes, of course I can build this feature in Rhino and then import it into Aspire.
Maybe it's just as easy, or easier, to do in Aspire directly (since, that is where the final model and tool-path creation will exist).
Maybe it's easier to do in Rhino. I don't know. I just know that I don't know how to do it in Aspire.
- highpockets
Sorry for it being so crude, but it looks like with the profile and some molding toolpaths it you could do the job with out having to cut the entire body from a model.
The other thing you could do is save the model in a .stl file, import it into Aspire then create a vector boundary then offset (inward) a copy that would incorporate all the areas that are milled, select both vectors then use the roughing and finishing toolpaths with Selected Vectors option. This would also cut down on machining time.
Hope this makes since.
- highpockets
You can also use two rail sweep in Aspire with multiple vector cross sections to control the shape of the curve in all three dimensions.
You can use your Rhino model (I would) and draw boundaries in Aspire to 3D cut the specific areas that need 3D cutting. The flat part of the back can be 2D cutting, which is far more efficient. You will need to do some sanding to blend, but it should be minimal.
Setting the cut heights to blend will be the more critical challenge.
- adze_cnc
Rather than exporting the Rhino model as OBJ or STL using a native 3DM file exported as Rhino version 4 (unless version 9 Aspire imports Rhino ver 5 models natively) tends to be a better import format (you might have to do a "join" on the surfaces first)
