Sign Foam Help
Posted: Wed Jul 12, 2017 7:15 pm
For all you sign makers,
While I have cut HDU signs for others, I have been asked by an associate to machine, finish and install four signs for his development. I will have two 1 1/2" x 32" x 136" pieces that need to be adhered to a concrete bricked pedestal. For these two I envisioned having the pedestal constructed with either studs or lag shields then bolting them on. I would of course, counter sink and plug. Does this sound appropriate?
The other two signs (1 1/2" x 48" x 72") will be mated back to back with a 1/8" tabbed steel sheet (that would be your local political bureaucratic BS) for stability and mounting. Should these be bolted through or glued to the steel (or both). If glued, what type of adhesive would work and be permanent?
Lastly, they want the sign finished with Sherwin Williams Resilience exterior gloss (provided). Any comment on number of coats for longevity?
Bill
Bill
