Rest finish type machining on a sign.
Postby rsetina » Tue Jul 11, 2017 6:05 am
I'm making some signs for a friend of mine and with the font I'm using, the .5 inch end mill won't completely remove all the material from the number four inside the triagular area at the top of the number. The corners aren't clean either where the leg and cross bar meet. My question is, is there a way to matching the sign with the .5 inch end mill and just clean the rest of the number four with a .25 inch end mill?
I uploaded an image and I hope it upload to the post so you can see to what I'm referring
Rick
Shark HD 2.0
rsetina
Model of CNC Machine: Shark HD 2.0
Re: Rest finish type machining on a sign.
Postby FixitMike » Tue Jul 11, 2017 7:29 am
Yes. You use the Pocket toolpath and check the Use Larger Area Clearance Tool box. The smaller bit will make all of the inside corners sharper.
I would suggest using 3/16" and 1/2" diameter cutters for this to get even sharper inside corners.
FixitMike
Postby Adrian » Tue Jul 11, 2017 8:37 am
If you don't see the Larger Area Clearance Tool section be sure to check the Show advanced tool options box at the top of the form. By default it's off so you won't see the other options.
Postby rsetina » Tue Jul 11, 2017 2:43 pm
Thanks for the info guys. I'll look for it. I knew I'd get an answer to my question here.
Rick
Shark HD 2.0
rsetina
