extrude feature
extrude feature
Postby Tduffy » Tue Jun 13, 2017 6:26 pm
Say I have a rectangle and would like to do an extrude with a 35 degree angle but I would like to keep one edge a straight vertical. Is this possible?
I'm not sure how else to explain this.
Thank you in advance for the help..
Tduffy
Model of CNC Machine: Laguna Swift 4 x 4
Re: extrude feature
Postby mtylerfl » Tue Jun 13, 2017 6:44 pm
Tduffy wrote:Say I have a rectangle and would like to do an extrude with a 35 degree angle but I would like to keep one edge a straight vertical. Is this possible?
Hi Tduffy,
Of course - it's not only possible, but doable.
Draw a sketch and take a picture, then upload it here for us to look at. I'm afraid your description is too vague to know exactly what you want to do. Lots of interpretations are possible. Your photo of the sketch will make it clear.
carvebuddy.com
Re: extrude feature
Postby Tduffy » Tue Jun 13, 2017 7:39 pm
Attached is a hand drawing if that would help.
Thank you
Tduffy
Re: extrude feature
Postby 4DThinker » Tue Jun 13, 2017 7:52 pm
The Moulding toolpath will do what you want very easily. I drew a vector representing the side view you wanted extruded. I drew a vector on the left edge to be the guide rail to extrude along. Use the guide rail vector, then click on the side view vector. Choose a ball nose bit for best results.
4D
Sample4D.crv3d
(99.5 KiB) Downloaded 113 times
4DThinker
Re: extrude feature
Postby Tduffy » Tue Jun 13, 2017 7:55 pm
Thank you for the help.
Tduffy
Re: extrude feature
Postby mtylerfl » Tue Jun 13, 2017 8:02 pm
Great that you provided the sketch. I had no idea you wanted it smoothed like that.
I used the Two-Rail Sweep and trimmed off one edge to achieve what I thought you wanted.
Also did an Extrude, but I realized it had three "straight vertical edges", so I eliminated that right away. (Turns out that was closer to your sketched illustration after all.)
carvebuddy.com
Re: extrude feature
Postby mtylerfl » Tue Jun 13, 2017 8:20 pm
Hmmm. Looking at your sketch again, are you wanting three edges tapered at the 35/degree angle? If so, the Two-Rail Sweep and trim would be the closest (you can make the sweep profile top corner smooth/radiused if required).
carvebuddy.com
Re: extrude feature
Postby Tduffy » Tue Jun 13, 2017 8:29 pm
Thank you.. This is all very good information and helpful..
Tduffy
Users browsing this forum: SteveNelson46 and 7 guests
