Large Monitor Layout Defaults
Postby miowera » Mon Jun 12, 2017 3:52 am
Hello Aspirers
Does anybody know how to set a default in v8.5 to ALWAYS display the left and right tabs (Drawing and Toolpaths) - I have a lot of monitor real-estate and it would be nice to do. I know about the tab "Pins" but I would like a default if possible.
Also any other cool ideas on how to take advantage of big screens would be appreciated.
TIA
Miowera
miowera
Model of CNC Machine: Roland MDX650 ATC-R
Re: Large Monitor Layout Defaults
Postby Adrian » Mon Jun 12, 2017 6:25 am
Main thing is to go into the Option on the Edit menu and make sure you have the three Save options under Window Layout set to Yes. That way any changes you make will be remembered. Once you've pinned them open with those set to Yes they will stay that way.
You can also drag the tabs to undock them as well to put them in different positions and redock them in different orders if needed. I actually have all my tabs permanently open on my 2nd right hand monitor with the left hand one being just the drawing window. Back when I had a single monitor I preferred to to have the drawing tab permanently open but the toolpath tab only open when needed.
Postby miowera » Mon Jun 12, 2017 7:01 am
Thanks mate, exactly what I was looking for.
miowera
Postby jarm2 » Mon Jun 12, 2017 4:29 pm
Thanks for the tip, Adrian. This makes for a much better work space and leaves more room for my drawing screen. I like having the two tabs on my other monitor.
Vectric Aspire, Cut3D, VCarve Pro, AutoCAD lite, Draftsight, Corel Draw X6, ViaCAD Pro 9, W 10
jarm2
Model of CNC Machine: C&CNC electronics
Postby Adrian » Mon Jun 12, 2017 6:51 pm
You can drag the Drawing,Modelling,Clipart and Layers tabs out into individual tabs on the 2nd monitor as well. I find that most useful with the layers and clipart as I work with those constantly.
