Need help with sharp internal corner
Postby frank131313 » Fri Apr 21, 2017 11:49 pm
i try to do a rectangle with sharp internal corner with a V-bit 90deg ... or a 120 deg and the result is not perfect does someone can teach me ....?
frank131313
Model of CNC Machine: biesse rover 30L2
Re: Need help with sharp internal corner
Postby Leo » Sat Apr 22, 2017 12:32 am
You MUST use the same cutter in the tool database when you create the toolpath as the actual cutter you use in the machine.
www.leosworkshop.com
Leo
Postby frank131313 » Sat Apr 22, 2017 1:40 am
yes its what i do
frank131313
Postby Leo » Sat Apr 22, 2017 1:43 am
The preview picture looks good.
From the picture of the actual cut it looks like the V cutter is a different angle than the tool path generation.
Leo
Postby scottp55 » Sat Apr 22, 2017 1:49 am
What software runs machine?
Looks familiar, like a setting problem I've seen with people that have Mach3(of which I know nothing)?
GMH
scottp55
Postby highpockets » Sat Apr 22, 2017 1:50 am
I agree with Leo, check your bit. Just because the label say 60° doesn't mean it is. Read this thread viewtopic.php?p=13653
Postby frank131313 » Sat Apr 22, 2017 1:35 pm
thank you ... i agree , i'm gonna check the angle ...
frank131313
Postby TReischl » Sat Apr 22, 2017 8:15 pm
Scott, I have been running Mach 3 about 10 years now and have never had it cause the problem shown.
That said, I have seen all sorts of problems when things got lose, or the bit was not as advertised, etc.
That is a new one on me?
Postby scottp55 » Sat Apr 22, 2017 8:26 pm
Sorry Ted:(
It reminded me of Constant Velocity(??) settings where it would over run a corner at first?
My mistake.
GMH
scottp55
Postby TReischl » Sat Apr 22, 2017 9:15 pm
Scotty, that could definitely happen. Decel set way too high and the machine slams into the corner, everything is stressed to the max and voila, overcut!
