Page 1 of 1
Problems setting Z to the base, and NOt tg the top
Posted: Sun Mar 12, 2017 4:13 pm
by Roskrow
I am trying to do an exercise making bowls, that was shown last summer by Vectric. The set up for sutting the Corian shows material as being .48 (it varies from sgheet to sheet !!0 They show Z as being inon the base and not on the top. This then creates provblems on tool changing. I can do it, but it is a slow process. Is there an easy way of doing it easily ?
Re: Problems setting Z to the base, and NOt tg the top
Posted: Sun Mar 12, 2017 4:17 pm
by Adrian
You can set the Z to the top on a job if you wish. Just be sure to recalculate the toolpaths and make sure the value you have in the job setup for the thickness is accurate otherwise it may not cut all the way through.
Posted: Sun Mar 12, 2017 7:18 pm
by martin54
Posted: Mon Mar 13, 2017 12:49 pm
by Roskrow
Thank you both...My goodness everyone is SO helpful.
I was, and will continue to do as Martin suggests.
Adrian I have asked a number of questions in the past several months, and you are always there with a respions...Thank you.
Best wishes
Malcolm (Roskrow)
