Pineapple Fruit Server
Postby James M » Mon Jan 23, 2017 7:22 pm
Just a quick question on the V-carve paths. I noticed that there was no flat depth for the V-carve paths. Is the depth determined by the width of say the diamonds on the edge?
J
James M
Model of CNC Machine: TBA
Re: Pineapple Fruit Server
Postby Mark's Wood Chips » Mon Jan 23, 2017 7:50 pm
James M wrote:Just a quick question on the V-carve paths. I noticed that there was no flat depth for the V-carve paths. Is the depth determined by the width of say the diamonds on the edge?
J
Yes, you are correct, same with the top leaf details.
Mark
Mark's Wood Chips
Model of CNC Machine: ShopSabre 23 with Rotary
Postby dealguy11 » Mon Jan 23, 2017 8:22 pm
Small clarification. If you don't set a flat depth, then the depth of cut is, in fact, set by the distance between the sides of the closed vector and the angle of the tool, as Mark noted. However, you can set a flat depth for a v-carve toolpath, in which case the depth will be limited to whatever you set. This means that if there are areas where the flat depth is shallower than the depth would be without it, those areas will be cut flat and will not have a "V" shape in the bottom.
Steve Godding
dealguy11
Postby James M » Thu Jan 26, 2017 8:37 pm
Thanks for the replies.
J
James M
