Page 1 of 1
Aspire stop inheriting shape
PostPosted: Sun Jan 08, 2017 7:19 am
by miowera
Hi fellow aspirers
I have a dome shape coming up from my Z plane. Easy!
Now I need to put a circular tube shape into the centre sticking up above the apex of the dome (think igloo dome with central chimney pipe)
When I create a component (aka chimney) using a circle it works except the top of the "chimney tube" inherits the curve of the dome. ie the chimney extrudes ok, but I can't seem to get a flat top on it.
Any chimney gurus out there come across this?
T.I.A.
Carl
Re: Aspire stop inheriting shape
PostPosted: Sun Jan 08, 2017 8:13 am
by eph210
Change the combine mode of the chimney from add to merge high.
Euan
PostPosted: Mon Jan 09, 2017 8:10 am
by miowera
Euan
Thanks for your reply.
I am on Aspire 8.5 ~ there is no "merge high" option that I can see. (doesn't mean it's not there, just that I couldn't find it)
Could you kindly point me to that option?
Cheers
Carl
PostPosted: Mon Jan 09, 2017 8:24 am
by miowera
Euan
Further to my earlier reply, I have discovered a change in the newer Aspire version that I wasn't aware of. The "calcs" now seem to flow backwards: ie from bottom to top of the model tree/stack rather than top to bottom.
Kindest regards and thanks for your advice.
Cheers
Carl
PostPosted: Mon Jan 09, 2017 9:34 am
by mezalick
Carl,
Euan meant to say "Merge".
You would adjust the height of the model either when you create the new component or in that components property.
See attached pictures.
As for the stacking of the components, you are correct.
This was done, on purpose, a few versions ago, so that Aspire would be more inline with other design software that are available.
Photoshop, which I use, stacks their items in that manner.
Michael
PostPosted: Mon Jan 09, 2017 9:58 am
by miowera
Michael and Euan
Thanks guys, with your much appreciated help I will have my chimney sorted in no time!
Aspire is such an awesome package.
Regards
Carl
PostPosted: Mon Jan 09, 2017 8:16 pm
by eph210
Glad to help out and Michael, thanks for correcting my post.
Euan
PostPosted: Mon Jan 09, 2017 9:07 pm
by martin54
eph210 wrote:Glad to help out and Michael, thanks for correcting my post.
Euan
I would have said "merge high" as well :lol: :lol: It did say "merge High" in previous versions didn't it or am I just imagining that ??
PostPosted: Tue Jan 10, 2017 3:27 am
by Xxray
Euan
Would be "combine" high/low I think.
