The need to sand after routing
Postby mservis » Wed Dec 07, 2016 5:45 pm
I am fiding that I have to significantly sand my projects after carving. Any suggestions on how to decrease the need to sand? I am using ash and oak.
Thank you
mservis
Model of CNC Machine: Laguna Swift 4x4
Re: The need to sand after routing
Postby Leo » Wed Dec 07, 2016 6:02 pm
There are many factors that come into play. It's not really possible to answer without knowing more about what it is that you are making.
Just facing or pocketing with a flat end mill will bring up different points then 3D with a ball nosed end mill and V-grooving, or periphery milling.
Can you be more specific?
www.leosworkshop.com
Leo
Postby Rcnewcomb » Wed Dec 07, 2016 6:09 pm
Also, photos will help in providing meaningful suggestions.
Postby mservis » Wed Dec 07, 2016 6:11 pm
I am making a 3D with a ball nosed end mill and v grooving a banner. From the clip art. However my pockets also require sanding (not as much), All my bits are sharp. I have tried slowing the speed and that helps some.
mservis
Postby Adrian » Wed Dec 07, 2016 6:34 pm
What sort of stepover are you using on the 3D?
Postby mservis » Wed Dec 07, 2016 6:42 pm
I am trying to get a picture for you from my phone. Just trying to figure out how.
mservis
Postby mservis » Wed Dec 07, 2016 6:43 pm
10 percent
mservis
Postby mservis » Wed Dec 07, 2016 7:21 pm
I my internet access is so slow here I am not able to up load the jpg file to send to the group.
mservis
Postby Rcnewcomb » Wed Dec 07, 2016 8:27 pm
You may want to email the photo to yourself so you can reduce the file size before you try to upload it.
Postby dwilli9013 » Wed Dec 07, 2016 8:33 pm
Great tip Randall,
Never thought to do that. I usually have to go back and resize in paint shop before I upload.
D-Dub
Dwayne
Dwilli
dwilli9013
Postby mservis » Wed Dec 07, 2016 10:10 pm
sample
mservis
Postby Rcnewcomb » Wed Dec 07, 2016 11:08 pm
What is the bit you are using?
How many flutes?
What is your feedrate?
Also, is the "dimple" part of the design or is the Z axis a bit off?
Postby mservis » Wed Dec 07, 2016 11:57 pm
1/8 ball nose 2 flute.
50.0 feed rate
And that is a wave in the design.
It is a large tree, that has 5 panels to make a family tree 48 x 48 so there a lot of waves like that in the design.
I thank you for any help you can provide.
mservis
Postby Rick O. » Thu Dec 08, 2016 12:57 am
More details or photos will make it easier to offer specific answers, but here are a few common suggestions:
Use very sharp bit
Use different bit, maybe a downcut type bit or different # of flutes
Apply sealer to wood before cutting
Change direction of cut
Change cut depth, take lighter cuts
Change router speed
Change feed rate
Cut design twice, or cut the outline again, to remove fuzzies
Run the board through a planer after cutting, to remove the top 1/32 or so of the board
Try different wood with same setup, see if cut quality changes.
RickO
Rick O.
Model of CNC Machine: CNC router
Postby mservis » Thu Dec 08, 2016 2:11 am
Awesome, Thank you
mservis
Next
