Flat Flags and Banners
- mezalick
I stumbled upon an alternative way to create flags and banners.
I use the distort tool to manipulate the component into the shape I want.
One note to share,,,you don't have to start with a flat component.
I have use several shaped components to create some interesting banners,,
I fine this method very easy and useful when I'm making my police badge models
I hope the following pictures can explain it..
Michael
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
- mezalick
Re: Flat Flags and Banners
And now for the rest of the pictures
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
- mezalick
Some finished work
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
- Model of CNC Machine: Joes Evo 3x2
I'll be doing a banner tonight, I'll give this a whirl. Looks like it will be a very quick, easy way to make all those folds. Thanks for sharing.
- Mike-S
Very slick--thanks.
- mike.davison
- Model of CNC Machine: CAMaster Stinger II with rotary
Great description of the process. Thanks for sharing.
- mtylerfl
Nice job, Michael!
- dealguy11
Thanks very much! Working on a banner later this week and will try it!
Steve Godding
- dealguy11
One tiny add to the directions. Maybe I just missed it. You need to bake the component after the fade and before the distortion, or the lower piece won't tuck under the taller piece at the right height. Had me scratching my head for a minute or two.
Steve Godding
- mezalick
You're correct Steve.
It must be something i did without thinking..
Without baking the program thinks there is no change in height...
Thanks for pointing that out..
Michael
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
- jarm2
- Model of CNC Machine: C&CNC electronics 4x4 ext aluminum table
Thank You for posting these directions on making a banner. I wouldn't have thought of using the distort tools to do this. Pretty slick. Have a great day.
Aspire 11 ViaCAD Pro 12 Corel 2019 W 10, 2.2 kw spindle wireless pendant
- dealguy11
Works on other models, too. I needed to make a couple of mods to this dove model, the biggest being the wrap-around wing. I cut the wing off the rest of the dove before making the change, so the body wouldn't get distorted, then baked them together again afterward.
Steve Godding
Nice! I have a banner to do and will give this a go...
- mezalick
I love it Steve.
The door of possibilities keeps opening wider and wider..
Nice work.
Michael
Nice work.
Michael
Michael Mezalick
mm@mezalick.com
mm@mezalick.com
- Model of CNC Machine: CNCRP PRO48X48
Great tip, thank you Michael! Will put this to good use today.
-Chris.
-Chris.
