Can I import .igs/stl/dfx/dwg/3d model
- Model of CNC Machine: Mazak/Probotix Meteor Fireball
My 3d model import is greyed out. I also need a good process for a guitar neck. Thank you all.
- mtylerfl
Re: Can I import .igs/stl/dfx/dwg/3d model
- Make sure you have started a new project before attempting to Import a modelpoolrod wrote:My 3d model import is greyed out. I also need a good process for a guitar neck. Thank you all.
- A good process for a guitar neck is the two-rail sweep tool
Thank you, I figured that out, now trying to get vectors off my stl, it won't select anything. Thank you.
- mtylerfl
You can auto-trace the STL model, then use the reduce nodes tool and manually edit remaining nodes...or just trace your STL manually with the vector drawing tools.
Thank you, Michael. I program and run large Mazak 5-axis at The Boeing Company with Mastercam and Catia, a friend has a Probotix Meteor Fireball router and wanted to make a Guitar, so far I'm failing, emc2 won't read Mastercam code or life would be good.
