Making a line thicker
Postby Xxray » Thu Jun 23, 2016 4:57 am
Should be simple but I am having problems with this, and/or have not spent enough time trying to figure it out.
I have this shape and I simply want to make the line thicker, which I guess would mean more or less copying it and making it a double line, and pocket in between.
Simply copying it and enlarging it doesn't work as the fit is right in some areas and totally off in others. Any simple method to make this, or any line "thicker", or do you pretty much have to manually trace around it or something ?
hwm.dxf
(68.69 KiB) Downloaded 153 times
Xxray
Re: Making a line thicker
Postby scottp55 » Thu Jun 23, 2016 5:41 am
Xxray,
Try an offset like this?
Postby Xxray » Thu Jun 23, 2016 5:49 am
I asked if there was a simple way and by golly, looks like that just might be it, thanks.
Xxray
Users browsing this forum: Exabot [Bot] and 8 guests
