cutting molding need help
Postby MarkJohnston » Wed May 11, 2016 11:27 pm
I need a comment on whether or not I should cut a relief in the back side of some molding I'm making.
I'm making some 5" wide molding that is suppose to match some 3" existing molding at least for the first 5".
I attached a end view picture of the 3" existing molding and a picture of the 5" molding sample that I'm going to be cutting. The back side of the 3" existing molding has a 1/16" relief cut that's about 1 1/2" long.
So my question is should I cut a 1/16" relief in the back side of the 5" molding? Is it cut to make the molding less resident to twisting or cupping over time?
Thanks for the help.
Mark
MarkJohnston
Model of CNC Machine: CAMaster MC4848
Re: cutting molding need help
Postby MarkJohnston » Wed May 11, 2016 11:29 pm
oops I forgot to post the cut sample.
MarkJohnston
Postby Rcnewcomb » Thu May 12, 2016 1:04 am
What material are you using? Hardwood, MDF, foam, etc.
Postby MarkJohnston » Thu May 12, 2016 1:46 pm
I'm using Oak to match the other molding. I have to produce 6 pieces 8 foot long.
Mark
MarkJohnston
Postby rscrawford » Thu May 12, 2016 5:14 pm
The relief in the back is mostly to help the molding fit better (in case of unevenness or protruding nails along the bottom of the drywall, etc).
Russell Crawford
rscrawford
Model of CNC Machine: CAMaster Cobra 408 ATC with recoil
Postby MarkJohnston » Fri May 13, 2016 9:39 pm
Thanks for the response guys.
I will cut the relief just to be safe.
Mark
MarkJohnston
Users browsing this forum: Google [Bot] and 5 guests
