construction of 2 solid surface seam vac clamps
Postby stankern » Sat Feb 27, 2016 11:15 pm
used 1/2 corian sink cut outs to make 2 vac clamps for joining solid surface pieces
just apply the pucks at the joint and use 2 clamps to pull in on the glue joint
takes a small vac pump 1/3 hp running at -18
The puck is flexible and 2 sizes of vac o rings can be used
https://youtu.be/ATDIdOZow1g
stankern
Re: construction of 2 solid surface seam vac clamps
Postby scubanimal » Tue Mar 01, 2016 9:52 pm
nice!
scubanimal
Model of CNC Machine: Stinger1 24, Shark HD2 Pro, Aspire,
Postby Woodbug » Thu Mar 03, 2016 4:37 am
I was thinking of making set of these. The commercial version of these clamps cost about $ 600.00. Alternately you could use compressed air vacuum generators instead. Are you able to turn off the pump once vacuum is generated?
Woodbug
Model of CNC Machine: Blurry Customs
Postby bravesoul » Thu Mar 03, 2016 11:50 am
Those are really nice, I might have to try to make some this year.
bravesoul
Model of CNC Machine: ShopBot PRT ALPHA 48"x96"
Postby AndyPitts » Thu Mar 03, 2016 4:48 pm
Nice.
Andy Pitts
AndrewPittsFurnitureMaker.com
YouTube AndyPitts1000
AndyPitts
Model of CNC Machine: ShopBot desktop
Postby stankern » Fri Mar 04, 2016 6:16 am
question"I was thinking of making set of these. The commercial version of these clamps cost about $ 600.00. Alternately you could use compressed air vacuum generators instead. Are you able to turn off the pump once vacuum is generated?
no if the pump is turned off the clamps release
And the 600.00 clamps also pull together no need for a manual clamp to close up the seam.
I have not been able to think of what to use so vac can pull on the 2 pucks
"not yet"
stankern
Users browsing this forum: No registered users and 7 guests
