A contractor friend asked me to carve a beaded spiral for the capitals of some columns he was building.
All he had was a sketch and some rough dimensions.
I was able to duplicate the outside of the spiral pattern using the Spiral Gadget
but the challenge was having Aspire produce a parallel spiral exactly 1/2" on the inside thus forming the 1/2" raised area for the bead. The final
result:
It took a number of steps to get Aspire to produce it without me trying to trace or draw. Is there an "easy" way to do this?
Spiraling Challenge
Spiraling Challenge
Cobblewood Carver
- Model of CNC Machine: Home built designs - 3'x4' and 5'x12'
Re: Spiraling Challenge
It will make them parallel, but you will need to scale the spiral to get the spacing to be 0.5". Use the Archimedes spiral type.
I used this gadget for the first time just yesterday to do it with text. The text was spiraling outward from the center. It took a minute to figure out that all I had to do to reverse the text direction was to node edit the spiral to put the start node at the outside end of the spiral. This is a test to get it to spiral correctly, and the text and the font style will change to something else.
CarveOne
CarveOne
CarveOne
- Model of CNC Machine: Probotix GX2525 with rotary
Try using the "ARCHIMEDES" spiral, for the first layout, then the "OFFSET" tool. It seemed to work for me.Fleming wrote:A contractor friend asked me to carve a beaded spiral for the capitals of some columns he was building.
All he had was a sketch and some rough dimensions. I was able to duplicate the outside of the spiral pattern using the Spiral Gadget but the challenge was having Aspire produce a parallel spiral exactly 1/2" on the inside thus forming the 1/2" raised area for the bead. The final
result: It took a number of steps to get Aspire to produce it without me trying to trace or draw. Is there an "easy" way to do this?
