Hot to, CNC miter
Hot to, CNC miter
Postby robert_woodguy » Sat Feb 14, 2015 5:03 am
Hi guys,
Since a photo's worth many words, from this :
Anyone has an idea what is the toolpath strategy, and how can it be done, what "special" tooling is needed to get such "crisp" miter lookalike corners ?
I'm.....lost :?
Thanks, Robert.
robert_woodguy
Model of CNC Machine: MechMete home build
Re: Hot to, CNC miter
Postby zeeway » Sat Feb 14, 2015 11:31 am
A vee tool can do sharp internal miter corners such as in your example. The rosette design may have been done by a small diameter ball nose tool...perhaps a 1/8 tapered ball nose cutter. You can also use a sharp vee bit with a tiny nose radius to cut such designs, but it would take a very long time.
Angie
zeeway
Postby Leo » Sat Feb 14, 2015 3:15 pm
I have not yet explored this - but - I think the "rest" machining strategy would be a good fit to do a project like this. This is where you would use all the normal tooling, like a 1/4 ball nose to rough 3D, and a 1/4 flat end mill to do some pocketing, then a 1/8 taper ball nose for the rosette and possible the frame profile. The rest machining would get into the corners and tiny details with a v-bit - maybe 60 degree.
It's a nicely challenging project.
www.leosworkshop.com
Leo
Postby Mike-S » Sat Feb 14, 2015 6:18 pm
This is a quick try with a 1/16hth BN.
Mike-S
Postby IloveVectric » Wed Feb 25, 2015 6:52 am
I used one of those ball nose cutters that tapers down to 1/32 at the tip.
Run a roughing tool path, then a finishing with the 1/32 tapered ball nose and a normal person will never guess it was made on cnc.
IloveVectric
Model of CNC Machine: Mach3 compatible
