using aspire with the new logic tracer
Postby stankern » Tue Feb 10, 2015 5:12 pm
Just received the new logic tracer drawing board VI from john walsh and put it through some tests
and used aspire for the editing
Also found how to control the amount of nodes produced on the diagram when drawing
The board is huge and will handle large projects
http://youtu.be/legcsfH0wIU tracing out a moose on logic tracer
stankern
Re: using aspire with the new logic tracer
Postby garylmast » Sat Feb 14, 2015 8:07 pm
When I was doing some intarsias, I finally figured out a fairly fast way to convert the line drawings into vectors.
1. The intarsia pattern I purchased from Judy Gale Roberts Studios, I took to FedEx Kinkos and had it scanned and saved as a pdf file.
2. I imported into Photoshop, changed it into grayscale and inverted it. Adjusted the levels slightly, erased parts of the images I didn't want and saved it as a tiff file.
3. Imported it into Aspire and did a trace bitmap, then exported it as a dxf file.
4. Dropped it into Adobe Actobat X Pro and saved it again as a PDF file.
5. Took it back into Photoshop to save it again as a tiff file, so I could imported back into Aspire.
6. Back into Aspire, the image now is very crisp and did another trace bitmap. The handful of flaws was corrected in node editing. The patterns now are already separated, so there's no need to offset if it was just a single line.
Although the picture shown is not totally complete and still needs a little editing, the total process of taking into the various software programs only took 5-6 minutes.
garylmast
Postby stankern » Sat Feb 14, 2015 8:55 pm
what you have done looks good ,I have not used the trace command in aspire
guess I should look at that
stankern
Postby IloveVectric » Wed Feb 25, 2015 3:11 am
Sure would be nice if Aspire's tracing worked better without doing all the "tricks" and manual editing.
Maybe they'll enhance it Version 5.
IloveVectric
Model of CNC Machine: Mach3 compatible
