3D WALL PANEL
3D WALL PANEL
Postby hassanjee » Wed Jan 14, 2015 9:22 pm
Dear Friend,
Kindly help me how can i create that attached photo wall panel on MDF sheet which tool-path i can select to make that on Aspire
hassanjee
Model of CNC Machine: Multicam 3015
Re: 3D WALL PANEL
Postby Adrian » Wed Jan 14, 2015 10:10 pm
You'll need to model it first then use the roughing and finishing 3D toolpaths.
Have you been through the tutorials?
Re: 3D WALL PANEL
Postby Mike-S » Wed Jan 14, 2015 10:47 pm
Use polytool to trace. (Yes, it's tedious.)
Then Create Shape (Dome).
You may want to smooth about 50%.
If this is a wall panel, it will be a long carve. Optimize tool and machine settings.
Mike-S
Re: 3D WALL PANEL
Postby hassanjee » Thu Jan 15, 2015 5:09 am
Dear Mike,
Thanks for your help could you please also tell me it's a wall panel,how can i Optimize the tool and machine settings.
hassanjee
Re: 3D WALL PANEL
Postby hassanjee » Thu Jan 15, 2015 5:24 am
Adrian wrote:You'll need to model it first then use the roughing and finishing 3D toolpaths.
Yes Please
hassanjee
Re: 3D WALL PANEL
Postby Mike-S » Thu Jan 15, 2015 10:54 pm
I don't know what your material is nor your machine, but you may want to experiment with bit size, depth of cut, cut speed, rapids, Z height and plunge speed. Also a "Z-Level" rough goes quicker than raster, but leaves more waste for the finish bit to cut. Be as aggressive as possible while maintaining an acceptable finish. The "clock" icon will give you an estimate of time to carve, but you need to do some carvings to get that tweaked so it gives a realistic estimate. My machine carved about 10-20% faster than Aspire's guess.
Mike-S
