Speaker wizzer cone
Speaker wizzer cone
Postby calgrdnr » Wed Dec 24, 2014 7:23 am
Need to reform center wizzer cone thinking 3 parts 2 inner 1 outside
How would you do it ? yeah it late hoping someone else tackles it before I awake :)
bought the drivers want to figure out repair then use for DIY speaker :)
Thanks for reading
Kent
calgrdnr
Model of CNC Machine: ShopBot prt with 4g upgrade
Re: Speaker wizzer cone
Postby Ms Wolffie » Wed Dec 24, 2014 7:47 am
What on earth is a speaker wizzer cone :?:
Cheers
Wolffie
Whatshammacallit
Ms Wolffie
Postby calgrdnr » Wed Dec 24, 2014 10:48 am
The cone that protrudes out of the in the center that is bent out of shape .
Just like my belly in the middle... unlike me I think simple mold 3 parts might enable me to
reset it to its original form :)
its suppose to smooth out frequency from the driver/speaker
thanks for reading Kent
calgrdnr
Postby Ms Wolffie » Wed Dec 24, 2014 2:19 pm
But isn't that one made from some kind of fibre?
Cheers
Wolffie
Whatshammacallit
Ms Wolffie
Postby calgrdnr » Wed Dec 24, 2014 6:56 pm
it is made from paper. figure I would get it moist reshape let it dry back out or make another either way a form would be good . :)
calgrdnr
Postby sailfl » Wed Dec 24, 2014 8:19 pm
Don't they sell the cone?
If you wanted to you could make a cone by milling it and then fitting the old one over it or slip the cone into the existing paper. I would be concerned of damaging what is around it.
sailfl
Model of CNC Machine: MechMate
Postby metalworkz » Sat Dec 27, 2014 6:44 am
Kent,
From the looks of the speakers you might be able to get away with just an internal cone to form the wizzer when wet as the base is trapped below and it seems if you only wet the damaged areas the internal form would push them back into shape without an external form. Never tried anything like this but perhaps that could be attempted and if needed then the external form could be made? Good luck with this and keep us informed what you end up doing and how it works.
Wes
Best regards,
Wes
wes.spence@comcast.net
Gingery Machines:
Lathe, Horiz. Mill, Shaper, Leaf Brake
metalworkz
Model of CNC Machine: SX3 CNC, DIY 24x20 & 48x60 routers
Postby calgrdnr » Sat Dec 27, 2014 7:46 am
Thanks for the idea Wes. I won them on ebay waiting to get them then will give it some more thought. might cut it off reshape and then glue back .
sailfl the speaker/drivers are from the 70's I doubt can get exact replacement . I always try to keep everything original if I can .
they will more then likely end up in a DIY speaker setup mishmash of drivers from different speakers I happen to have extras of .
calgrdnr
Postby kyeakel » Sat Dec 27, 2014 4:06 pm
I wonder if you could use a fabric steamer, that way it won't get too wet or take long to re- set the shape?
Kipp
CAMaster Stinger 1
Shopbot PRT 9648
Aspire 8
Cut2d,Cut2dLaser
kyeakel
Model of CNC Machine: Camaster Stinger I, Shopbot PRT 9648
