BabCad .cad
BabCad .cad
Postby Rolland Johnson » Mon Dec 22, 2014 1:47 am
I used to use BobCad-Cam & have a lot of files I would like to have in Aspire. Is there a way to import ".cad" file to Aspire?
Rolland Johnson
Model of CNC Machine: Home Made - will be a CaMaster III 4'x4
Re: BabCad .cad
Postby metalworkz » Mon Dec 22, 2014 4:18 am
Perhaps you can load the file in the software it was created with and save as a file format the is on the list in the Import Vectors drop down of Aspire? I am not familiar with your software at all so I don't know what formats are available, but most 2D drawings are good in .dxf format.
Best regards,
Wes
wes.spence@comcast.net
Gingery Machines:
Lathe, Horiz. Mill, Shaper, Leaf Brake
metalworkz
Model of CNC Machine: SX3 CNC, DIY 24x20 & 48x60 routers
Re: BabCad .cad
Postby Rolland Johnson » Mon Dec 22, 2014 4:59 am
That's what I was thinking I may have to do. I think it can be saved as a dxf.
I'll try that
Rolland Johnson
Re: BabCad .cad
Postby m.marino » Mon Dec 22, 2014 10:30 am
Which version of other software? If it is models I would suggest that you use .stl for your export model. I have had issues with other software in the past and don't use it any more (highest version I used was 23). I wish you the best of luck as I have had serious issues with that software.
Michael
Live is Live it
Aspire 8.5, Shark v10
Computer Lenovo D20
CNC control via Mach3
MM0MSU
m.marino
Model of CNC Machine: Gantry Router - self designed
Re: BabCad .cad
Postby Rolland Johnson » Tue Dec 23, 2014 4:20 am
I loaded other software & saved as .dfx & it loaded right in. Thanks for the advice.
Rolland Johnson
