copy object along vector
Postby COWBOY1296 » Thu Oct 23, 2014 2:00 pm
I am not sure this needs to be fixed or even if it can. In an effort to copy objects along the vector, it looks great until it gets to the corners. Is there a way to fill it in evenly?
COWBOY1296
Model of CNC Machine: SHOPBOT BUDDY PRS 32, 4 FT PWR STICK
Re: copy object along vector
Postby PaulRowntree » Thu Oct 23, 2014 4:14 pm
I think that corners are always a problem, both for the math and the intuition. What would you want the software to do in the corners/
Paul Rowntree
PaulRowntree
Postby COWBOY1296 » Thu Oct 23, 2014 4:27 pm
Not really sure but there seems to be a problem in the corners, but if it is cant be fixed then i can live with it. I just wanted to make sure that i was not missing something.
COWBOY1296
Postby glenninvb » Thu Oct 23, 2014 4:51 pm
For a quick fix you could delete the corners and replace with the nice v shaped one I circled, If you deleted half of the border you would only have to manually fix 5 then mirror.(delete the two extra center ones) Or even a single "bump" manually aligned in the corners. Use the original vector as a guide (offset if needed). sometimes just changing the number of copies helps with corners.
The bottom point looks a little strange, probably because of number of copies as well, mirroring half of the design may help symmetry.
glenninvb
Model of CNC Machine: homebuild / VCP 8.0
Postby antennasDIY » Sun Oct 26, 2014 1:45 am
Hey cowboy I was just going to start doing this exact badge shape. Do you have anything you would be willing to share??
antennasDIY
Model of CNC Machine: Home made
Postby antennasDIY » Sun Oct 26, 2014 3:00 am
I can't do PM's.... antennas@yahoo.com will work..
antennasDIY
