Vac Hold Down System
Postby Lameiii » Wed Oct 22, 2014 12:43 am
I've been using hold down clamps up to this point in time. I'd like to convert to a vac hold down system but not sure what it encompasses.
I'm looking for information on how to set one up and what equipment I would need to purchase.
Any help would be greatly appreciated.
Lame
Lameiii
Model of CNC Machine: Romaxx WD1
Re: Vac Hold Down System
Postby Rcnewcomb » Wed Oct 22, 2014 1:21 am
What are you cutting? That will make a difference.
Here are a few links to get you started:
CNC Cookbook: Fixturing with Vacuum
Vacuum Hold Down Strength for CNC
BradyVac II
Good information at AllStar
Postby Lameiii » Fri Oct 24, 2014 1:23 am
I'm only cutting wood.
Lame
Lameiii
Postby dldecker » Fri Oct 24, 2014 2:29 am
Lameiii wrote:I'm only cutting wood.
Lame
plywood, MDF ? vac hold down system works good
lumber - large pieces or small pieces
2 x 12 it works ok, smaller pieces 2 x 6 I would use clamps
Dana Decker
Aspire 8 something
CaMaster Stinger I
dldecker
Postby Lameiii » Sat Oct 25, 2014 3:44 pm
Does anyone sell vac table parts.
Lameiii
Postby feinddj » Wed Nov 05, 2014 6:58 am
What kind of vacuum?
Regenerative vac or a shopvac type vacuum system will work for plywood and some wood parts but the vacuum hold down is a log function of the area. The bigger the area, the stronger the hold down. try Lighthouse, BradyvAc or Black box vacuums. A search on Ebay will find regenerative pumps that can provide lots of vacuum power. When I am cutting ply I use a regenerative pump which works fine for most parts. Some care may be needed as to where the cut starts and which bits are cut first, etc.
For smaller items, I use hard vacuum with a gasketed fixture to hold the piece. For example, I have a 2 inch thick p[iece of walnut that is machined with a 1/2 inch ball mill inside and out to a depth of 1.875. The walnut is 4.5 by 5.25 inches. I use a bit of uhmw with a venturi pump to hold it down. I screw the uhmw right to the table.
David
feinddj
Postby PaulRowntree » Wed Nov 05, 2014 10:41 pm
Lameiii wrote:Does anyone sell vac table parts.
have you seen this guy?
http://www.joewoodworker.com/veneering/welcome.htm
Many places sell pods...
Paul Rowntree
PaulRowntree
Postby Ms Wolffie » Sat Nov 08, 2014 5:04 am
http://www.sorotec.de/shop/product_info.php/info/p1531_vacuum-table-600mm-x-420mm-sorotec-edition.html
I just bought this vacuum table but the company carries several others. The price is minus 19 percent tax so it is reasonable.
http://www.sorotec.de/shop/index.php/cat/c177_Vacuum-Tables-Vacuum-Tables.html
German quality.
Cheers
Wolffie
Cheers
Wolffie
Whatshammacallit
Ms Wolffie
