fit curves to vectors
Postby dimtil » Sat Sep 20, 2014 12:31 pm
Hello!
I have a question about the mode " fit curves to vectors".
In Aspire 3.0 can I correct the vectors manually?
If the answer is yes, how?
(I saw this in tutorial for Aspire 4.0 http://www.vectric.org/video/aspire4-vcp7/getting-started/A03/A03-w.html in 17:40.)
Thank you!
dimtil
Re: fit curves to vectors
Postby Adrian » Sat Sep 20, 2014 1:19 pm
I can't remember in which version that tool came out. If it's not in V3 then you would need to do it by hand using node editing. Select the vector you want to to work on a press N to go into node edit mode. You can then use the right click menu to choose various options (or press the short cuts keys) to change the type of the spans and nodes. It's not easy to do which is why the tool came out.
It's well worth upgrading to the latest version. There have been many worthwhile changes and additions since V3.
Postby dimtil » Sat Sep 20, 2014 1:24 pm
Thanks a lot Adrian!
dimtil
