Two Rail Sweep Troubles
Postby Hunterland » Thu Sep 04, 2014 9:59 pm
I have been away from this for some time and have been trying to make this column with a 2 rail sweep could some one look at this file and give me some impute as to what I'm doing wrong. Could this be modeled as one complete component with the end caps on? It needs a channel in the back to fit the frame work of the sign? if I can carve it from a single piece 4 inch's thick registering the channel would be much easier Thanks for any and all help. Don
column file.crv3d
(166 KiB) Downloaded 150 times
Hunterland
Model of CNC Machine: prs standard
Re: Two Rail Sweep Troubles
Postby mezalick » Thu Sep 04, 2014 10:51 pm
Don,
Something like this ??
If so, use the two side vectors as the rails..
Michael
Michael Mezalick
https://carveddetails.com
mm@mezalick.com
mezalick
Postby Hunterland » Thu Sep 04, 2014 11:03 pm
Yes Just what I wanted but what was I doing wrong. over and over again. Where did you get the profile shape from ? Thanks a lot Don
Hunterland
Postby mezalick » Thu Sep 04, 2014 11:21 pm
Don,
Did you have the " scale across section ,," option selected in the two rail sweep. ???
Playing with those option will result in different component shapes.
As for the profile,,it's one of your vectors ,,,1/2 of the largest circles that you have on the right side , off from the working area..
~M
Michael Mezalick
mm@mezalick.com
mezalick
Postby mezalick » Thu Sep 04, 2014 11:29 pm
Don,
Here's a copy of my file with the vectors I used.
I hope it helps.
~M
column file MM.crv3d
(30.5 KiB) Downloaded 167 times
Michael Mezalick
mm@mezalick.com
mezalick
Postby Hunterland » Fri Sep 05, 2014 12:19 am
Michael
Yes I had the same check boxes as your checked , I attached the files again . I close the rails maybe I should not have done that. I will go back and try that thanks again for your help. Don
Hunterland
Postby mezalick » Fri Sep 05, 2014 12:33 am
Don,
First select the left rail then the right, click on the "use Selection" button.
Then click on a vector that is a half circle...
Use my vectors in the file
~M
Michael Mezalick
mm@mezalick.com
mezalick
Postby Hunterland » Fri Sep 05, 2014 1:03 am
DAHHHHHHHHHHHHH That's what I was doing wrong all along I was selecting all 3 and then hitting use selection . [b]THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!Don
Hunterland
