Tangents to a circle or arc
Postby dhellew2 » Tue Sep 02, 2014 1:13 am
Sometime my brain works sometimes it's just really slow.. :?
Create the circle at the desired location
Draw two vectors from the center of the circle at the desired angle
Offset each vector the radius of the circle
Clip the unneeded part of the circle and you will have two vectors tangent to the circle
To create tangents to a center point arc draw temporary vector lines at 90° to the desired tangent lines
Create the center point arc
Draw vector lines snapped to arc ends at 90° to temporary vectors
Dale
Dale
dhellew2
Re: Tangents to a circle or arc
Postby FixitMike » Tue Sep 02, 2014 1:53 am
Much easier to download and install the Tangents gadget from here: http://gadgets.vectric.com/index.php?op ... Itemid=186
FixitMike
Postby mtylerfl » Tue Sep 02, 2014 2:50 am
Great tip, Dale. Thank you!
Postby dhellew2 » Wed Sep 03, 2014 1:31 am
FixitMike, Thanks, but I already have the tangent gadget and have used it.
It doesn't work too well to create tangents at a specific angle.
It only creates tangent vectors between two circles which can be made to work if the angle of the tangent lines are not critical, or by doing some trig calculations to size the circles and the distance apart necessary to achieve the desired tangent lines at specific angles.,.
Michael T, hope you can use it.
Dale
Dale
dhellew2
Postby FixitMike » Wed Sep 03, 2014 1:56 am
The offset function is quite useful for this and other constructions. I often use it to construct a fillet between two arcs. Offset both arcs by the radius of the desired fillet, and draw a circle with the desired fillet radius centered where the offsets intersect, and then trim away. Sometimes you have to draw lines between the centers of the fillet and the original circles first, as the trim tool doesn't always recognize tangent points as intersections.
FixitMike
Postby dhellew2 » Thu Sep 04, 2014 11:26 pm
Mike, Is this what you are creating? Dale
Dale
dhellew2
Postby FixitMike » Fri Sep 05, 2014 1:13 am
Dale: No. Here's a picture of what I was describing.
FixitMike
Postby dhellew2 » Wed Sep 10, 2014 6:15 pm
Thanks Mike, now there are a couple new uses for offsets. Dale
Dale
dhellew2
