tracing bitmaps
tracing bitmaps
Postby jmckee » Wed Apr 16, 2014 12:52 am
I have a plan for a baby cradle that I scanned on the big scanner at Kinkos. I want to cut the pieces out on the CNC.
I imported the TIF files from the scans into Aspire using the Import Bitmap for Tracing function, and then traced the bitmap. It seems like the editing of the tracing is taking a long time (hours). The lines that were drawn in the tracing process aren't nice and smooth. They are jagged and broken, requiring me to do a LOT of node editing.
Is this normal operating procedure for large pieces that are traced like this? Some of these pieces are going to be 33" long, so this is not a toy, it is a full size cradle. I have spent several hours today and am still not finished.
Is there a better way to do this? This was scanned a few years ago, so I don't remember the resolution of the files. When looking at them on the computer screen, they look pretty good. I do know it was the best we could scan at the time.
Any ideas or tips, or is this normal when tracing bitmaps?
Thank you!
jmckee
Model of CNC Machine: Digital WoodCarver
Re: tracing bitmaps
Postby FixitMike » Wed Apr 16, 2014 1:07 am
After I trace a bitmap, the first thing I do is use the Fit Curves to Vectors tool with Bezier Curves. This will eliminate a lot of nodes. Then I edit the nodes to smooth the picture. If there is a crevice or spike, I just delete the nodes that are off the smooth line. Faster than trying to move them.
FixitMike
Re: tracing bitmaps
Postby ssflyer » Wed Apr 16, 2014 1:32 am
Tracing a bitmap makes closed vectors around your lines - not what you want for this.
If your original plans have all the dimensions, it's probably easiest to simply recreate it from the dimensions in Aspire.
If you don't have dimensions, then use the drawing tools to recreate the bitmap, manually.
Ron Sloan
ssflyer
Model of CNC Machine: ShopBot PRSAlpha 96x60
Re: tracing bitmaps
Postby rscrawford » Wed Apr 16, 2014 2:16 am
You could probably draw the design yourself in a couple hours, and then you know that the dimensions are all exact so the cradle will fit together properly!
Russell Crawford
rscrawford
Model of CNC Machine: CAMaster Cobra 408 ATC with recoil
Re: tracing bitmaps
Postby martin54 » Wed Apr 16, 2014 10:41 am
Well worth the time taken to learn how to use the drawing tools properly, as has already been said you could probably have manually traced this a lot quicker than trying to edit an auto trace.
You would be surprised just how quickly it can be done with a bit of practice.
Users browsing this forum: jarm2 and 3 guests
