Those are pretty amazing. Do you take custom orders? I need a ball-nose for milling some edging on a set of cupboard doors.
I've not yet had any success in making one with the techniques that you have identified. Mine always seem to break when I run it into the clamp. What RPMs were you using? Maybe I just had it spinning to fast. The evidence of my attempts appears very plainly on my clamps.
Gordon
The all new "Round Corner Drill"
Re: The all new "Round Corner Drill"
Are you using the right bits Gordon, you need to be using HSS bits to manufacture these. Carbide bits are to brittle & will just break. Find some really cheap naff bits & then you can probably make these quite easilygordread wrote:Those are pretty amazing. Do you take custom orders? I need a ball-nose for milling some edging on a set of cupboard doors.
Gordon
- gordread
- Model of CNC Machine: CNC Professor HDX
martin54 wrote: Are you using the right bits Gordon, you need to be using HSS bits to manufacture these. Carbide bits are to brittle & will just break. Find some really cheap naff bits & then you can probably make these quite easily
Ahhh, that must be it. Most of my bits are Freud Carbide or are PrecisionBits. I'll have to find some at the bargain bin.
