ellipsoid
ellipsoid
Postby aaron1869 » Sat Jun 02, 2018 3:53 pm
I have a customer that wants me to make an ellipsoid mold. The mold needs to be 3"X28"x28" with a depth of 1 1/2" at the center. I can create a dish that extends from 0" to 1 1/2" at the center. The problem is he needs that slight curve on the outer edge. The only way I could get it, or close, was create a 28" circle with a dot in the center and then use a 2 rail sweep. That created the correct outside edge but gave me a raised center. There must be an easier method.
Aaron
aaron1869
Model of CNC Machine: piranha
Re: ellipsoid
Postby FixitMike » Sat Jun 02, 2018 4:26 pm
Try the moulding toolpath. With this bit: http://www.rockler.com/rockler-flattene ... 2-in-shank it will be much faster than using a 3D toolpath. edit: Oops, I think this will leave the raised spot.
2nd edit: Here's the solution: viewtopic.php?f=2&t=26332#p188919
Or add a small pocket to the center to get rid of the raised center.
Also, this tutorial should include the information you need, even though the emphasis is on two sided cutting. https://release.vectric.com/clipart_bowl/
Or, search the forums for "bowl" to see what else pops up.
FixitMike
Re: ellipsoid
Postby aaron1869 » Sun Jun 03, 2018 8:08 pm
A bowl profile will not work.
aaron1869
Re: ellipsoid
Postby aaron1869 » Sun Jun 03, 2018 8:45 pm
The solution was easier then I thought. What I initially did was correct. All I needed to do was drop the model 1/8" below the top. The bit has just enough curve to create an ellipsoid.
aaron1869
Re: ellipsoid
Postby TReischl » Mon Jul 09, 2018 12:22 am
The last I knew an ellipsoid was a deformed sphere? Scaling done along one or more of the axis. If there is no scaling, then the object is a sphere. I suppose you could say that a sphere is a special case of ellipsoid.
http://www.tedreischl.com
Low Profile CNC Router Vise
Model of CNC Machine: 8020 Build 48X36X8 RP 2010 Screenset
Users browsing this forum: No registered users and 7 guests
