Importing your old Tool Database into the latest version.
Postby Mark » Mon Nov 29, 2010 1:34 pm
To Import your Aspire Version 1.0, 2.0 or 2.5 Tool Database into Aspire Version 3.5 / 4.5 / 8.0
The same instructions also apply to importing in a VCarve Pro older than Version 6.5 into version 6.5 / 7.5 / 8.0
or Cut2D 1.1 into 1.5
1. Open the older version of the application.
2. Create a new file.
3. From the main menu, click Toolpaths, then select Tool Database.
4. Minimize any tools open in the Tool List tree window, by clicking on the minus box
next to the expanded item.
5. Highlight the topmost group in the tree browser.
6. Click on the Import button.
7. Navigate to the location of your old tool database.
In the case of Aspire version 2.5, if you installed the application using the default setup,
on most English versions of Windows, this will be located at:
C:\Program Files\Aspire V2.5\ToolDatabase.
(C:\Program Files (x86)\Aspire V2.5\ToolDatabase - for 64 bit windows).
In the case of VCarve Pro version 5.5, if you installed the application using the default setup,
C:\Program Files\VCarve Pro V5.5\ToolDatabase.
(C:\Program Files (x86)\VCarve Pro V5.5\ToolDatabase - for 64 bit windows)
In the case of Cut2D version 1.1, if you installed the application using the default setup,
C:\Program Files\Cut2D V1\ToolDatabase.
(C:\Program Files (x86)\Cut2D V1\ToolDatabase - for 64 bit windows).
8. Click on the tools.tool_db file and click Open.
9. Your old tool database will now have been imported in to the later version tool database and be contained in a new group, which has
been given the name New Group.
You can rename this group to be whatever you wish.
Mark
Vectric Staff
Return to Aspire - General
Users browsing this forum: No registered users and 15 guests
