Aspire and Cabinetmaking part 2
Postby cabnet636 » Mon Sep 07, 2009 2:15 pm
ryan patterson of http://www.cabinetpartspro.com/ has created a nesting program that allows me to define my door sizes then nest and produces a parametric .dxf that when imported into Aspire allows me to add details and carvings. thanks to ryan this makes mdf door production to a small shop possible with out spending BIG bucks on software and IT guys.
http://www.cabinetpartspro.com/Nester/Nester.htm
jim
cabnet636
Model of CNC Machine: CAMaster 508 ATC
Re: Aspire and Cabinetmaking part 2
Postby cabnet636 » Mon Sep 07, 2009 2:36 pm
we will be able to use all profiles!!!
here is whiteside which is available on amazon.com
http://www.woodworkersworld.net/mdf_sti ... Bits.shtml
also the onsrud 47-02 and up series of bits!!
https://www.onsrud.com/xpost
cabnet636
Postby moto633 » Mon Sep 07, 2009 11:25 pm
Jim,
Is that in his cabinet parts pro or is it something else he offers?
Couldn't you just make your door sizes in aspire and nest them or am I missing what your doing?
Nick
moto633
Postby cabnet636 » Mon Sep 07, 2009 11:42 pm
aspire does not do parametric, in other words i had to make each door and its parameters seperatly each time i had job, there may have been a way to do this but it was beyond me so i asked ryan to do this and it is excellent, today i spent more time studying how to set waste and other settings and got to 88 % waste which is acceptable to me
this is a program he has written in addition to cabinetparts pro, which he recently upgraded and it is excellent!
jim
ps, i also spent the day drilling out the rear axle tension bolt that i broke off in my swing arm on my crx450 i figured you can relate to that!!
cabnet636
Postby cabnet636 » Mon Sep 07, 2009 11:44 pm
a bit larger so one can read it!
jim
cabnet636
Postby cabnet636 » Fri Sep 11, 2009 2:29 am
i recieved the dxf of the whiteside machine company tools for mdf doors from the company today
i have seperated the profile to create form tools for those who would like to have them.
they are in actual scale so do not change them and they will match bits perfect
the tools are shown on page 25 of whiteside's catalog
http://www.whitesiderouterbits.com/wm_catalog_2007.pdf
jim
witeside bits dxf.crv3d
(152 KiB) Downloaded 165 times
witeside bits dxf.dxf
(151.82 KiB) Downloaded 124 times
cabnet636
Postby Bob_S » Fri Sep 11, 2009 11:36 am
Jim;
thanks
I am working on setting up files for some picture frames. I want to try to layer up some deep carved frames made of MDF and wood. These profiles just saved me a couple of hours of work.
Bob
Even though you are on the right track - you will get run over if you just sit there.
Will Rogers
Bob_S
Postby cabnet636 » Fri Sep 11, 2009 11:55 am
excellent!! i am running first full set of doors today and have worked on setting vectors in correct offsets
here is using the 5630 on outside and inside profile at .3625 deep and using the 5725 at .3 deep
jim
cabnet636
Postby moto633 » Sat Sep 12, 2009 2:51 am
Jim,
What do you use to prime your mdf with before paint? I use a good bit of mdf for fixtures and glue size it before paint on all cut edges and always wonder if there is a better way.
Also how do you have your aspire windows set up? I can't seem to get my windows to look like that??? :?
thanks,
Nick
moto633
Postby cabnet636 » Sat Sep 12, 2009 3:16 am
i close the toolpath and drawinf tabs using the pins at the top of each this opens up the screen then zoom in and do a screen capture, (i use picassa there are others)
we use a nanochem vinyl sealer primer, when you come to sc i will see if george from spray one systems will stop by he is the best coatings rep i know!! one coat on rawcut mdf second on all surfaces then sand, powders well
cabnet636
Postby kevrgood » Sun Oct 25, 2015 1:18 am
I purchased your software on line through your website..The did not receive any downlaod instructions as the server crashed..How do I get my software?
kevrgood
Postby cabnet636 » Sun Oct 25, 2015 2:03 am
Not sure I understand ??
cabnet636
Postby Ms Wolffie » Sun Oct 25, 2015 5:54 am
cabnet636 wrote:ryan patterson of http://www.cabinetpartspro.com/ has created a nesting program that allows me to define my door sizes then nest and produces a parametric .dxf that when imported into Aspire allows me to add details and carvings. thanks to ryan this makes mdf door production to a small shop possible with out spending BIG bucks on software and IT guys.
jim
It says file not found :( :(
Cheers
Wolffie
Whatshammacallit
Ms Wolffie
Model of CNC Machine: SharkPro+HD Heavily modified
Postby rasputin » Sun Oct 25, 2015 6:32 am
i dont know if this helps or not. but at the end of the message about file not found, there was a part in blue.
i clicked on it. and got into there web site. then opened other products. and found a nester program. all i need is a key.
i think that may work if they sent you a key.
Return to our homepage http://www.cnccabinetcutting.com http://www.cnccabinetcutting.com
rasputin
Postby Ms Wolffie » Sun Oct 25, 2015 8:46 am
Thank you Rasputin, I didn't see that one.
However, that only leads to the CPP not the nesting one.
Cheers
Wolffie
Whatshammacallit
Ms Wolffie
Next
Return to Aspire - General
Users browsing this forum: No registered users and 17 guests
