RFL in the import aspire?
how can I do?
HELP ME
RFL FILE ARTCAM IN ASPIRE
- JamesB
- Vectric Alumni
Re: RFL FILE ARTCAM IN ASPIRE
You can't ArtCAM is a different program and RLF is the native format for that software. You could ask the person sending you the RLF file to save it as an STL from ArtCAM instead and import that into Aspire.
James
James
You know this, I thought there was a program that automatically.
Thank you
Thank you
Hello.
I asked same question long time ago. You can convert RLF file to STL in ArtCam. Go to relief menu->create triangle mesh, create triangles->save triangles in STL. Now you should be able to use Artcam files in Aspire.
Hope this helps
Ilkka
Hope this helps
Ilkka
