Trying to attache an aspire 3d file for help and it won't load because of size??
Andy K
Need help
Need help
Andy K
- TReischl
Re: Need help
Yup, there is a limit to size. Probably the best thing to do is just attach the vectors as an eps. Or you could try to describe what you are doing and see if we can all figure it out. Sort of like charades on a computer!
- Thkoutsidthebox
Re: Need help
Take a screen capture of the file or use Save Preview Image in Aspire, and post that, then tell us what's up. Also, if you zip it, it might go small enough but I dont know how big is "too big" !!
Re: Need help
Trying to get the wine glass to show up proud of the bottles without the bottles showing thru
Andy K
- Turtle49
Re: Need help
Try setting the wine glass component to "merge" and then increase the base height until it is raised up above the wine bottles....
Hope this helps,
Tim
Hope this helps,
Tim
Tim Hornshaw
www.HornshawWoodWorks.com
- TReischl
Re: Need help
And if that fails, use the outline of the wine glass to "punch" out the model of the wine bottles, then model your wine glass in the hole and raise it up. (Tim hates that method cause you cannot move the glass around after that, he has a point there)
By the way, nice design!
Re: Need help
Got that to work, thanks for the help. Now I only need to figure out how to toolpath it!
Andy K
