2X4 indicator of oversize
I've had problems downloading 3d in my trial Aspire which I never had in Cut3d. When I hit the OK button on the material size the 3d shape turns into a 3d board. Finally figured it had to do with size of the figure. So what is the largest size of 3d object the program will accept?
- Mark
- Vectric Staff
Re: 2X4 indicator of oversize
Hello argreen,
There is no limit on the size of model that you can import, but a common mistake that
can be made, is failing to hit the "Apply" button after one of the Model size values
have been altered.
Although the other values will scale accordingly, the new values are not saved unless
the Apply button is pressed.
I hope that this makes sense and is of some help.
Mark.
have been altered.
Mark.
